Обновилась версия форума ! (Как Full так и Lite)
Собственно, все темы, что здесь есть уже неактуальны. Оставлены для истории.
Только чтение.
Administrator
Администратор
Администратор
Сообщение Administrator »
Код: Выделить всё
 brand new release of Fully Modded's phpBB pre-modified software, FM2014.3.58 is the latest version and is highly recommended that you update and only use this new version as it fixes many security issues addressed by phpBB2.0.14, as well as addressing the bugs found since the last official Fully Modded release.
The full version release package (available in both .zip and .gzip formats) can be used for a new installation, to upgrade a FM2013.3.58 board or to upgrade a phpBB2.0.6+ board (phpBB2.0.6 thru 2.0.14); just make sure you follow the correct documentation very carefully. Seperate update packages with the changed files only are also provided for both the full and Lite versions.
Documentation and instructions on both how to install, update, chmod, etc are found in the E-Manual.
Note: All existing 2011.3.65 themes and languages are still compatible with this new 2014.3.58 version.
http://support.phpbbfm.net/viewtopic.php?t=6443
Вернуться в «Архив со старыми и утратившими актуальность проблемами»
